メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
AirMac Extremeベースステーションと同時に発売されたこのハードディスクを搭載したモデルは、802.11ac対応のタイムカプセルNASです。
Time Capsule not powering on
I've been using this device for about 1 year until one day I found the light blinking amber. The Airport app was reporting the device was overheated. I pulled the plug and waited for it to cool down and when I plugged it back in there was no light at all. All I could hear was the noise of HDD spin up and nothing seemed to work.
It's out of warranty so can't take it to apple.
I cracked it open and found out that the PSU seemed to be functional. I checked the output voltage and it was a solid 12 Volts. But the fan doesn't run at all. I even tried to apply voltage to the fan to see if it runs but it didn't.
I checked the fan socket on the mainboard and 12 Volts appeared on the multi-meter.
Can I be sure that the fan is faulty? Because I don't want waste money on a PSU to find out it was not necessary.
BTW can someone verify that a working TC acts like mine when no fan is connected.
Thank you
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
10 件のコメント
@shoeib hey bro, did you find a solution?
さんによる
@ironjer - I'm sure a new fan fixed the cooling issue
さんによる
@jesus no man. I eventually came to the conclusion that the logic board is fried.
さんによる
@shoeib maybe a bake... mine TC no fan spinning and no front light either but, the hard disk power on. I don't want waste money in new PS. :(
さんによる
@danj I have no front light and no fan spinning, just the HDD works. Maybe the Logic Board is failing...
さんによる
5件以上のコメントを表示
コメントを追加
2件の回答
ベストアンサー
More likely the fan died here. For about $20 US you should be able to find one.
I don't have a A1470 TC right now but I've had to replace quite a few fan units across the entire line of TC's
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Do you by any chance remember how the TC acts with a faulty fan?
Thank you
さんによる
@danj would TG Pro read this?
さんによる
@mayer - TG Pro won't work here. It only works under OS-X or MacOS. The TC's use a custom file system and its own OS. AirPort Utility will report if the unit is overheating.
さんによる
コメントを追加
See if any of the following articles can help:
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
shoeib さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 28
今までの合計 3,491
