メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Xiaomi Redmi Note 3 Proスマートフォンの修理ガイド。2017年発売。
Why is phone not charging?
Hi there, the thing is that i have less than a month with the phone but it suddenly stopped charging. I didn't drop it and it never touched water, so I have no clue what happened. Already tried pressing all buttons, leaving it charging all night, etc. Any ideas?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 10
22 件のコメント
Have you connected the USB cable to a computer or a different charger to see if it charges?
さんによる
Yeah I already did
さんによる
open back cover.... open usb charge socket DO short circuit usb SOCKET AND TOUCH A WIRE OR A METAL THING BOTH SIDES BAC OF THE USB CHARGIN PLACE DO IT 2 OR THREE TIMES THEN IT WORKS..... MY TWO PHONES WORKED THE MAIN REASON WHY THEY DONT CHARGE IS USING SOME FAST CHARGING CHARGERS OR POWERBANKS...... DO WHAT I SAID IT WORKS
さんによる
Can you explain how to shortcircuit the charging port?
さんによる
Yes how to do the short circuit thing? Can you explain step by step
さんによる
17件以上のコメントを表示
コメントを追加
5件の回答
ベストアンサー
Hi,
Use a strong light and a magnifying glass to visually inspect the USB charge port.
Check that the pins are all there and that they are straight and parallel with each other. Also verify that there is no lint or dust in the port enclosure.
If there is dust or lint, do not use a metal probe to try and remove it as you may damage the pins. Try a vacuum cleaner, using short sharp bursts to see if it removes the debris. If it is still there after trying a vacuum cleaner, then using a wooden toothpick very gently pry it out.
If there is nothing in the USB port and as your phone is less than 1 month old , I suggest that you consult the warranty section in the documentation that came with the phone as to what you have to do to make a claim for a manufacturer's warranty repair or replacement.
このアンサーは役に立ちましたか?
スコア 7
8 件のコメント:
I had same issue with my note 3, it wasn't charging normally and have to put it in a unique position to charge without disturbance.
To fix it, I just pushed the charging pin inside the phone charging socket a little upward.. Light n gentle push with a flat steel pin. And it worked, and is charging in any position I throw.
さんによる
It worked for me..thanx..had tried software update,developer options etc but your method was the only effective one..
さんによる
My phone is not charging quickly than as usual
さんによる
My phone is not charging properly..once i switched off my phone and connected the charger then its working after that i removed charger and connected it is not charging...what is the problem...
さんによる
My phone betery percent coming in-2
さんによる
3件以上のコメントを表示
コメントを追加
Xiaomi Redmi 3x - I developed a charging problem with my Xiaomi because of using a fast-charge cable that apparently wasn’t compatible with the phone and the phone dropped to 0% and just wouldn’t charge.
Please note: If the light below the home button isn’t on (Solid, not blinking), the phone isn’t charging. I left the phone plugged in for 18 hours and it had no effect.
  1. Remove the back cover (that was quite difficult without the correct tools and I ended up snapping off some of the siding. Would recommend the correct tools and watching a few youtube videos on this.)
  2. Unclip the battery cable to the main circuit board.
  3. Plug the phone in, this will cause the screen to come on
  4. While the Mi-Logo is displayed attach the battery cable again (before the battery percentage displays)
  5. The phone will enter a charging state for around 2 minutes and then stop charging again.
  6. Repeat step 2-4 until you’ve got the phone up to around 8% battery (the battery % indicator will fluctuate anywhere between 8-20%)
  7. Boot up your phone
  8. While the phone was on I had the charging state fail several times until the phone reached 11%. I just repeatedly plugged it out and back in. After around 11% the phone continued to charge normally.
  9. Other things to note: One post said to turn the volume up to Max and disable Wifi, I did both
PS: Using a USB cable to PC wasn’t good enough as the small charge provided wasn’t enough to charge the phone to where the screen would turn on properly.
PPS: In some cases the phone went into a loop of screen-on/screen-off. In this case, I disconnected both the battery connector cable and the battery sensor cable and left it to vibrate for a while, connecting and disconnecting the cables while in a “boot” state, seemed to get it out of this state eventually.
PPPS: If the battery connector cable disconnected from the main PCB then the battery percentage will always display 0% even if it’s not the correct charge.
Part of me is afraid that if the phone battery ever hits 10% the problems will occur again, but hopefully it won’t.
I’ve also ordered a new charging circuit PCB on the internet to replace the current one in the phone.
At first I thought it might be the battery that’s the problem, but after reading many posts and realizing that the charging PCB is cheaper than a new battery, I thought I’d give that a try.
Unconfirmed:
Deeper research states that there’s a “zener diode” on the main PCB board that can burn out when your use a charging cable that’s voltage is too high. This can be removed and will allow the phone to charge, but it’s not recommended as the phone’s voltage input won’t be regulated anymore.
Edit: I eventually replaced the charging PCB on the phone when the new one I’d ordered online arrived, which resolved the issue completely.
It’s not terribly difficult, just removing the back cover, unscrewing, unplugging it and screwing in, plugging in the new one.
A new charging PCB is most definitely cheaper than buying a whole new phone.
Please do make sure that you get the right model number though, as it needs to fit perfectly into the phone. The one I bought ended up being slightly off from the original, so the phone case at the back is distended after closing everything up.
このアンサーは役に立ちましたか?
スコア 5
3 件のコメント:
it worked for me. for xiaomi mi 6. Thank you..
these are the symphtoms:
-last day battery drained too fast and smthg wrong with temp sensor show me
-10Celcius around,
-empty battery icon will show up when i press the power button
-plug in the charge with cable battery icon with lightning symbol and stand for a while then blank screen
-almost all combination (fastboot, safe start etc) didnt worked
-plug in and pressing power button show up the mi opening logo for a sec but immediatelly coming blank battery with lightning icon
solution which is described replied post
remove the back case
remove the battery socket
plug in socket again and try recharge again
second times it worked for me.
good luck.
さんによる
i need to try this but my phone is 0% right now
さんによる
Great stuff, thank you
Just to add to this commentary:
I had this loop and I solved plugging the battery in a 'right' time when the logo first appears. The cellphone then started to charge.
さんによる
コメントを追加
Check if the adapter and the usb cable are working properly ( even if you use the original one. ) If they are okay, then probably the problem is lint. Try cleaning the charging port with a toothpick or paper. Try restarting the phone and charge again.
If nothing works, its best to take your phone to the service center.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
But charger is functioning properly with other mobile ,another mobile charge properly without failing and get mobile full charge.
さんによる
my cable is also functioning properly with other mobile
さんによる
コメントを追加
I had the same problem the solution that worked for me is to shut down the phone and charge it.
after a few days of doing that it goes back to charge normally
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
It happened to my phone too. It was dead for like almost 2 weeks. And then I let it charge whole day, it turned on just for 3 days. Now it won't charge again.... It is really killing me.
さんによる
What is the problem...how to solve this
さんによる
mi lite y not even mobile I purchase new one now from 20 days phone working good but charging as problem 1% 50% R 100% get suddenly swith off. I as changed battery new. also. guide me
さんによる
try to mi lite y sugesst me
さんによる
コメントを追加
I had the same problem with 2x redmi note 3 pro. It was supposed that quick chargers interact with the phones before sending higher than 5V though the usb, but apparently, they dont.
The first time, it burned a fuse that is right before the USB connection of the upper board. I had to remove ti with some pliers. After that the phone worked normally, but the phone was unprotected by not having the fuse.
Now, some months later, the phone refuses to charge with many chargers and/or cables. even on the PC it charges only when it is recognized as a device, which makes me think that is a deeper problem, probably, the chip controlling power or charging are half dead. For this phone according to the schematics, the chips are: PMi8952 (power management) or SMB1351 (charger chip). The fuse that needed removal appears as FV2106 in the schematics and it’s a ESD5661D07-2 if you wanna get it of aliexpress and replace it.
It’s noteworthy taht the lower charging board also has the same fuse. This fuse is expensive, so ALL the chinese fake lower PCB replacement don’t have it, they simply replace it with some resistors. If you comapre both board (original and chinese replacments) they differ heavily both in PCB layout and components.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Daniela さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 35
過去 30 日: 120
今までの合計 212,168
