メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
1.86GHzもしくは2.13GHzプロセッサ、フラッシュストレージは128GBもしくは256GB
Will not start up
My MacBook air stopped recently and I have been unable to start it I Have attempted to reset the smc to no avail. I have disconnected the battery and attempted to start it will the power connected again to no avail. Is this an i/o problem?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
Remove the logic board and charging board, and clean any liquid damage using 95%+ isopropyl. If you are getting a charger light when a charger plugged in, it is likely the trackpad cable (check both ends, if burnt or liquid damaged, replace), trackpad PCB (check for burns or corrosion) or most likely the keyboard.
If there is no light on the charger, check the I/O cable for burnt pins. It could be the I/O cable, charging board, keyboard (shorting PP3V42_G3H to ground) or PP3V42_G3H is not being produced on the logic board, or is being shorted to ground.
Clean any liquid on the board first, but take a picture of where it is corroded before cleaning. If no liquid on the board, most likely will be the keyboard, if the charger is lighting up and the trackpad cable is fine.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
William Hawkins さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 21
今までの合計 729
