メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nokia N8は、Symbian^3オペレーションシステムを搭載した最初のデバイスであり、2010年におけるNokiaのフラッグシップデバイスです。
Not Starting and Charging
I bought a nokia n8 2 weeks ago. Was using my phone sending text messages when it suddenly hung up and shut down. When I tried to power it on it won't start and tried to recharge it but the indicator light does not go on meaning it does'nt charge. Has anybody experience this with a nokia n8?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 7
2 件のコメント
I got Same Problem Please Help Me
== Update ==
Whenever I Try To Start The Phone It Is Start I Can See Nokia Logo Also But Then Suddenly It Is Going To Switch Off
Please Help Me.
さんによる 共有
try Hold "powerkey" about 8s/10s he gives you 3 vibes
if not turn on hold "powerkey" till phone awake
good luck
さんによる 共有
コメントを追加
6件の回答
最も参考になった回答
Same here. What i do for the moment is connecting to pc with usb cable- so that starting to charge via usb- would let u to start up the phone. simple and quick. but better refurbish the phone
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
If you encounter the thing that the Nokia N8 won't charge and worst, if the battery was drained and the N8 shutted down and won't charge or power on, try the following steps.
1. Connect the charger supplied with the N8 to other compatible Nokia phones, like E72 like I did.
2. Wait for the other device (E72) to start charging.
3. After it starts charging, remove the charger from it (E72).
4. Now, try to charge the N8 using the supplied charger that you used with the other device previously (E72).
5. Wait for the N8 to charge or start.
6. DONE!
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
bro, thx, it worked!
(with the additional usb connected to a computer and then folowing your steps)
さんによる 共有
and removing the sim
さんによる 共有
コメントを追加
have yo held the power button when turning it on it does take a few seconds you can aslo try charging both through the power at the bottom and the mini usb at the side .
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
please all remove memory carn and sim card, then start your phone
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Try to charge with a normal charger like samsungs charger. In the side of Nokia N8 there is a port for it. Worked for me :)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
In the left side*^
さんによる 共有
コメントを追加
Try replace the battery
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Victor さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 21
過去 30 日: 81
今までの合計 26,683
