メインコンテンツにスキップ
2.4GHz, 2.7GHzもしくは2.8GHz クアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大 3.8GHz) with 6MB 共有 L3 キャッシュ。
Where I can find the OEM Battery?
I want to know where I can fin the OEM replacement battery for my Macbook Pro 15 Retina Early 2013 A1398 . I saw one on this page but is out of stock but I still don't know if it is compatible with my model any help please.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
3件の回答
ベストアンサー
It’s currently in stock and also carries a 1 year warranty!:
MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery
Replace a 8680 mAh battery compatible with MacBook Pro 15" Retina Mid 2012 to Early 2013 A1398 model laptops. 11.26 Volts (V). 99 Wh (Watt Hours). Battery model A1417.の画像
製品
$79.99
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Yes, but I said OEM. I see several complaints this isn't good as OEM.
さんによる
Then you'll need to visit Apple and let them fix your system. No one offers new OEM batteries (other than Apple). You could find a used battery and that's about it.
さんによる
コメントを追加
You won't find an OEM battery for any Apple computer unless it is taken from another computer. Apple does not sell parts to their products, I would assume, because they want you to pay the costly markup of them fixing it for you.
I highly suggest giving the new one (it is stated to be up to OEM Specifications, otherwise just as good, if not better, than the original Apple part) on this website a try - I did, and it's working great. The repair process was rather tedious and lengthy, but worth it if you don't want to invest $2,300 or more on a new MacBook Pro. It was also for an A1398 Model, Early 2013 15" Retina.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
@elvisgonzalez I found this and says the brand is apple and the guy has a 99.2% positive feedback.
http://www.ebay.com/itm/Original-OEM-Bat...
Hope this helps!
- Jainore
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
It says out of stock and it says doesn't fit 2013 models but thank you!
さんによる
@elvisgonzalez oops, this one says in stock. Sorry about that!
http://www.ebay.com/itm/NEW-Apple-MacBoo...
さんによる
I think that one would not fit my mackbook because its late 2013 :/ and mind is early 2013 but thank you for trying to help!
さんによる
コメントを追加
回答を追加する
Elvis Gonzalez さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 2,615
