メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2006年に発売されたCanonのPowerShot Aシリーズのコンパクトデジタルカメラ。6.0メガピクセルのカメラと4倍の光学ズームレンズを搭載。
DIY "hot" spring fix
I have an A530 that was included in the recall for the "hot" spring but I didn't know about it and Canon won't fix it now. Does anyone have a diagram of what the problem was and the DIY fix that I've seen talked about, but never described?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
John Darago this was recalled because a little hinge spring in the door of the battery compartment can stick out and short the batteries. Result is poor battery life, and a hot battery door.
画像
You could try to shorten the spring, use a small Dremel like tool with a cut of wheel or simply place a piece of electrical tape over it.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I don't know if all A530s are like this, but I took the battery contact plate off by removing the two screws. The back side of the plate had a slot that the arm of the spring was supposed to fit into. I guess when it was assembled, the spring arm wasn't placed properly. If you decide to examine this, be careful. There is a little spring behind the plate that could "spring" away.
さんによる
Those springs in the battery doors are the major reason why I do not like to work on cameras. A royal PITA to deal with those :-)
さんによる
コメントを追加
回答を追加する
John Darago さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 22
今までの合計 671
