メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HTC HD2は、HTCが製造し、Windows Mobile 6.5オペレーションシステムを搭載したスマートフォンです。
Can you replace a cracked screen
I have two phones that have had their screens severely cracked.
Can you buy replacement screens? If so where and how do you fit it?
Thanks
Update
I replaced my screen on my HTC HD2 and the screen comes on when its not in the shell but when i put the phone back in the shell to place the screws in it does not come on i feel the vibration that the phone is coming on but the screen does not and when i take it back off it comes on i looked for any shortages but did not find also the cable that the buttons are attached to is broken could that be the problem any any solutions
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Jeffrey, if this is a new question, you should really ask it for yourself. It looks like you answered a question. Check on the right hand side of this page , you will find a link that says "Ask A Question" it is not hard to do but will make sure that people see that you are asking. Good Luck
さんによる
コメントを追加
15件の回答
ベストアンサー
Ebay is your friend
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I second that one. I'd be lost without it :)
さんによる
コメントを追加
I am currently replacing the screen and lcd on a HTC HD2 and will put up a guide with pictures as soon as possible. However if you have a questions in the meantime email me on cwconline@hotmail.com
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Anyone after parts let me know might be able to offer cheap price and uk shipping
さんによる
コメントを追加
On the internet I found this manual.( see the link) Be carefull when you are to the step foulding the screen and phone open, I broke the "AP board". That is the board (thin foil) under the 3 buttons below the screen. I bought the screen in China, 40 dollar but this is ONLY the glass and you still have to split the glass from the several capacitive and touch layers. This part is not described in the manual. I am searching for the AP board and the way how to replace only the glass. Do you have a AP board for sale?
Good luck
Walter Jansen.
Amsterdam Holland
walterja@telfort.nl
www.crunchgear.com/2010/03/02/official-htc-step-by-step-video-for-disassembling-the-htc-hd2/
Update
Hello CWC.
Can you help me with the AP board ?( small print foil under the 3 buttons.
Thanks, best regards, Walter Jansen
Update
I clicked on the logo but cannot find the guide, is this for the HTC HD2 or for Iphone and other HTC type ( than I have found the guides). Can you tell me if you have a the printfoil for the 3 buttons on the front for me?
Is there someone that can repair my HTC HD2 for me? I have a broken glass, bought a new glass but have difficulties assembling the touch screen layers.
Thanks,
Walterja
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
OK, that video is helpful to a point. Problem is, it shows a factory prototype that isn't glued together in any way like the production model is. You can see the white grease paper is still on the double sided tape on the back of the LCD. I'd call that cheating.
さんによる
コメントを追加
I replaced the Glass on an HTC HD2 today. It was painful but doable. As soon as I get another one to replace I will make a very detailed guide on how to repair and replace the glass and other parts.
If anyone has an HD2 with a broken glass they are willing to ship to me, I can repair it (provided the part or cost of part) and can make a guide as well.
Note: When ordering the part you need to be sure you order the digitizer compatible with the T-Mobile version.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I unsuccessfully replaced the glass on an HD2 today. After I got it back together the touch screen was unresponsive and I apparently damaged the LCD in the process. There are now several horizontal lines going across the display. Also, it didn't fit together really well after reassembly. I'll try again tomorrow.
I would rate this procedure a very difficult.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Tried again today and it looks like I bricked it. Won't power on. No response to anything. Sh*t!
さんによる
if it's like an iphone that won't power on i'd check the battery terminals before declaring it bricked
さんによる
コメントを追加
Gary try this.
Remove the battery. Now plug in the AC adapter. With the AC adapter plugged in, slide your battery in. Your phone should turn on. If it does, it means you broke the AP board (which has the power button on it). If it dosn't, then check all connections. You don't need the back cover installed in order to turn the phone on BTW.
Try it out plz and let me know.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I've been doing phones for a while now, pride myself in fixing anything, I am a 25 yr component level tech. To replace the glass on this thing is nearly impossible the digitizer and the touch screen are fused together. the phone its self is very cheaply constructed and difficult to reassemble. not worth doing
Serg
lizzjord@yahoo.com
Update
This is prety cool , ok in response to my last post, Jason C commented on my post. Thanks Jason I had gotten lazy, thanks for calling me out on this one, I must explain though I own an electronics repair shop in Mercedes Tx,I am a one person operation full time, I work on anything electronic. I started doing Phones Cause its a great source of quick income. In my case if a phone is dificult and time consuming to do its not worth it to me. I can repair almost anything on an Iphone in about 5 minutes that include the i4. I apolgize to you guys for last post and will keep in mind that is site is for people who want to fix their electronics on theirown and not necessarily for people like me. My knowlege of the repair business is vast if I can help any one please feel free to ask. Again I apologize for the bad post thanks to all who responded.
Serg
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hello lizzjord,
You sound like a reputable tech, however you are wrong. The LCD and digitizer are now not fused together. The phone is not hard to reassemble.
I also believe $35 is better than $450 or more for a replacement phone.
さんによる
コメントを追加
If you click on my logo I have two unpublished guides that include videos and check out the one on the left hand side should help you.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I used Magicmymobile. I just did a search on Google. They can fix anything and specialise in HTC HD2 handsets.
magicmymobile.co.uk
Ian
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have successfully fixed several HTC HD2 phone digitizers. YES this is a VERY difficult phone to work with and if you do not seat the parts back together, it can give you problems from not turning on to turning on with the charger connected to shorting out on you. However, it is a DOABLE task with extreme care and precision. You have to know where the cables are and how to disassemble it correctly. Else, you will have a phone in pieces which will not work or some parts will break on you. That said,if you need any help with this device, you can email me at and i will do my best to help you through it. We also sell parts for this and many other devices, if you don't find what you are looking for there, call us at
So if you feel confident enough and want to do it yourself, we can supply you with parts at a very reasonable rate and also provide support. please check our website for part availability at
Thank you,
Fahra
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Fahra, very nice answer. Please put your email address, phone number and website url on your profile. Otherwise this could be interpreted as spam. Thanks you.
さんによる
コメントを追加
interesting reading, i recently disassembled my HD2 to replace the main flex due to it being broken by the previous owner when he replaced the screen, i took some extra time to reseat the lcd as it appeared the previous repair had no located it properly, once i re-assemble the phone the touch screen stopped working, anybody got any ideas on what could be wrong, i was as gentle as possible?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
After I replaced my screen, the glue between screen and lcd has been removed on most parts and that makes phone with holes for dust and so on.
Is there any place I could by that sticky tape to put it back on an replaces screen (digitizer)? For me would be good either precut or non-precut tape.
Thanks in advance for sharing information.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
it's just double sided adhesive made by 3M. you can buy it anywhere
さんによる
コメントを追加
@Jason C
I have a phone that I definitely wouldn't mind you using as a tutorial! I can provide parts, even a little compensation! I just cracked the digitizer recently and I'm really upset about it. I've replaced digitizers before, but the htc hd2 seems a bit out of my league. I'm not sure how to PM, but if you contact me I would really love any help...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hey Kasen,
You can e-mail me @ jason@jasoncousins.com if interested. I do not see any type of PM feature on this site yet.
さんによる
コメントを追加
I have just had my screen repalced on my HTC HD2. I used MagicMyMobile. They are new company but offered a first class service. You can find them on Google. www.magicmymobile.co.uk
Ian
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
"I replaced my screen on my HTC HD2 and the screen comes on when its not in the shell but when i put the phone back in the shell to place the screws in it does not come on i feel the vibration that the phone is coming on but the screen does not and when i take it back off it comes on i looked for any shortages but did not find also the cable that the buttons are attached to is broken could that be the problem any any solutions"
Maybe it is a little bit late but for the ones who possibly will face with this problem I would like to give the solution. I had the same problem with my HTC HD2 after replacing the touch screen, than I found that the touch screen soldering to the Display was poor and I solder it again now carefully and strong. The problem solved. Hope this helps.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
John さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 27
今までの合計 35,204
