メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung NX Miniは、2014年3月に発売されたミラーレスデジタルカメラです。
My camera wont focus
My camera is having trouble with auto focus. On auto I can hear it trying but the picture just get more blurred. On the smart settings I can get it to focus but it requires zooming in more than I would like.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
see if motor focus len is work free and correctly, if it have a slack in gear, possibly have to change th lens.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Another thing you have to check is the linear resistor - ie the sensor that detects the focal length. If the ribbon is loose from its connector, it may not giving this information. So it is stuck at a specific focal length. You can check if this is it, if the you can see picture on the LCD before you rotate the lens to the normal shooting position. I mean, when the lens is in its OFF position.
In order to access the aformentioned connector you need to:
1) Remove the back cover
2) carefully remove the ribbon that is attached to the outer contacts by lifting up the lock mechanism on the back side of the connector (the opposite side of where the ribbon is inserted).
3) There are 2 connectors remaining, the smaller one is the one to check.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi! So if I can see an image even if the lens is in the "off" position, that would mean I have that "locked at a specific focal length" problem?
さんによる
コメントを追加
回答を追加する
Shatia Thompson さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 33
今までの合計 1,603
