Reset to factory settings
When I reset my MiTravler back to factory settings it comes up all the time to input some codes ( numbers) in order to proceed, how to bypass and reset manually
この質問は役に立ちましたか?
この質問は役に立ちましたか?
leroysimpkins, from pg.17 of MiTravler manual.
Restore default setting, if you want to reset the factory setting and erase all materials, please press,
Settings → Backup & Reset → Factory data reset.
Link to manual below. Good luck.
このアンサーは役に立ちましたか?
what about the up/down key while pushing the on button
leroysimpkins, Yes you can try that it works on some devices, also note below,
From page #3 in your manual. Important Notice
-If the device is freezing or stuck, press the reset button(a small hole) or
long press power button for 7 seconds.
-When the performance is slow after using some applications, it is
recommended to close running application in setting menu.
過去 24時間: 1
過去 7 日: 13
過去 30 日: 29
今までの合計 2,538
1件のコメント
My mitraveler tablet is froze up need to reset it how do I do that
Richard martinez さんによる 共有
