lens will not close when powered down
my son walked into someone and now the lens will not close when powered down. how can this be fixed
この質問は役に立ちましたか?
この質問は役に立ちましたか?
sherri126 , Fully charge the battery and try on/off several times while slapping/bumping the bottom of the camera, remove battery for a couple minutes and reinstall to see if it resets. If this does not work, because of the intricate/small delicate gears that control the lens to function may be jammed, it should be looked at by a good camera repair Tech. Have a good camera repair shop have a look, diagnose and estimate repair. Good luck.
このアンサーは役に立ちましたか?
Strangely I slapped the bottom twice and now it seems to be fine...thanks
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 14
今までの合計 437
