メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
WD50FB2530は、Westinghouse Electric Corporation社製のテレビです。
How do I select OK manually without a remote?
How do I select the function OK without a television remote? I need to retune the tv (and have even bought a universal remote) but I still have to do it manually i.e. On the display itself. Tried every option, please help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 20
30 件のコメント
Neither of these options work, and programming a universal remote control is useless. The codes do not enable the use of the OK button which is critical to the OTA programming of the HD-56FH9* Model JVC TV. This seems to be a collosally huge oversight by JVC, their imbedded buttons on the side of the TV are just as worthless as the the engineers who made this mistake.
So to JVC I say WTF
さんによる
Did u ever fix ur issue? im having the same problem.
さんによる
Did mine by pressing both up and down vol buttons at same time, menu butt first then channelbutt for Auto tune then both vol buttons for ok
さんによる
Have a jvc tv with bulit in dvd and freeview no remote how do i setup
さんによる
How can I turn on my TV without my remote control?
さんによる
25件以上のコメントを表示
コメントを追加
12件の回答
最も参考になった回答
use both volume buttons at the same time.
このアンサーは役に立ちましたか?
スコア 11
8 件のコメント:
I went an bought a universal remote as well. Britney’s comment end up working though. Thanks!!!
さんによる
Thanks so much!!
さんによる
Thankyou i had this problem spent hours trying to work ot out pressed up and down volume buttons at the same time and worked perfectly xxxx
さんによる
I have a telefunken tv and I have tried to press the up and down volume buttons but it's not working or how long should I wait when pressing the buttons.
さんによる
I have a hisense tv there are volume buttons - up an down buttons- a tv off and a input button so 7 buttons but no ok button what should i press for the ok button
さんによる
3件以上のコメントを表示
コメントを追加
I guess there are many different ways to change the input without a remote control then, because I changed my input by pressing volume up THEN very quickly, channel down
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I have a GPX and I also get to scan channel but idk how to make it scan I tried to press ok to start scan but didn't work what is the button you press to get it to take yes
さんによる
コメントを追加
Hey Josh Paradise,
Most of the times it´s the menu button itself wich you can find on the tv.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
My TV has no buttons at all on the set itself and I can't find the remote control anywhere
さんによる
My problem, exactly. My power button only toggles the input source up and down
さんによる
コメントを追加
On the JVC model HD-56G786...
In order to press “ok” without a remote, I had to hold the “menu” button on the right side of the TV, and while holding press both volume buttons at the same time.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
What if button on bottom no buttons on the side?
さんによる
What if the menu button is the same as one of the volume buttons?
さんによる
コメントを追加
Hi @rundrummergirl ,
Looking at the user manualfor your series TV you need the remote control unit or a universal remote to do most of the functions on the TV including setup.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I have a alba Freeview/dvd TV. Lost the remote. How do I change channels, on the side there is an on/off button, volume +/- buttons and one to change modes(TV/dvd etc). Got a universal remote but won't work!!!!!!! HELP
さんによる
@Elaine Hannigan
What is the model number of the TV?
Looking at a few of the user guides linked there are program channel up and down buttons. You just press them and the channel should change. You would need to press more times to step through each of the stored channels in the TV in the order that they were first stored, to get to the one that you want.
Did you enter the correct TV code into the universal remote?
さんによる
コメントを追加
I had to autoprogram channels on my Emerson TV without a remote. First, press menu and then follow the up and down commands. Next, press the volume and menu buttons at the same time to signify, “OK” or “Select”. That’s what worked for me so I hope that helps someone else!
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
I have JVC TV Model LT-32DE75 need to operate without remote
さんによる
I have my DVD stuck and I switch TV on it operate I don't have remote control how do I pull out the DVD without remote
さんによる
Need to find or buy a jvc tv remote with the 3D option... Cant find any
Or how to put on the 3 d option
さんによる
Please how can I select language without my TV remote on skyworth 32inch
さんによる
Have already reset my TV
さんによる
コメントを追加
On my model td910b how do I get the cursor to move without using a remote plz help
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
How do I get the Ok button on RC 2040 remote control?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have a Emerson tv no remote how do I hols ok button for 3 seconds
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
After opening the TV I can move to where I need but can't reach to enter
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
my tevison 2019 but idk how to press select when there is no &&^&^$^ select butons
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi @williambell148,
さんによる
コメントを追加
How do I select ok on my jvc 52inch not smart tv without the remote control
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Josh Paradise さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 35
過去 30 日: 189
今までの合計 267,455
