メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
1.5 GHz Core Solo、1.66 GHzまたは1.83 GHz Core Duo、あるいは1.83 GHzまたは2 GHz Core 2 Duoプロセッサを搭載。 2006年初頭から2007年中盤までの、Intelプロセッサを搭載した初期のMac miniモデルについて解説します。
Anyone found an alternative Mac Mini outer casing?
Hi! I recently acquired a 100% functional Mac Mini from a recycler, the only catch being that the outer casing has been destroyed, and so the guts of the Mini are exposed, and it's not really in re-saleable condition. I've looked into replacing the casing, but it seems a little silly to spend $50-$100 that people are asking.
Does anyone have thoughts on a practical alternative to Apple's Mini case? I'd prefer something on the practical/discreet side, as opposed to goofy and outrageous.
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
If you end up with it in the cube case or the floppy disk drive, you should take some pics and link them here so we can take a look at what you did.
さんによる
コメントを追加
4件の回答
ベストアンサー
How about a nice ammo box. Lay it on its side, cut the top for the CD drive. Larger boxes could be used for extra hard drives. Comes with a carrying handle.
http://www.amazon.com/Military-Ammo-Wate...
For a bigger box, use the 50 cal version: http://www.amazon.com/Military-Surplus-C...
Here's a bunch of various goodies: http://www.colemans.com/ammocan.htm
Consider using the dome from a iMac G4 with out the screen attached.
このアンサーは役に立ちましたか?
スコア 3
6 件のコメント:
Or an old mac cube case would be awesome! but the little research I did I couldn't really find one for much less than $50.
さんによる
Awesome idea Mayer! I'm going to seriously consider it...my only concern is that the metal might keep wireless from working, but I'm sure there are ways around that.
R Trent, thanks for the idea...I have an old Cube around, so I'll see if it fits...that would potentially be a fairly easy solution.
さんによる
good answer +
さんによる
Yeah WL might be an issue- also it'd add a TON of weight, probably not good for ventilation either though, do you have a CNC machine?
さんによる
The cube's a great idea- in fact, it's upgrading the Cube so you get some sort of Mac Cube? Cube Mini? Whose origins cross processors and years.
さんによる
1以上のコメントを表示
コメントを追加
Here is one that mayer came up with on Meta that I really like.
http://www.pcworld.com/article/170973/co...
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Oh wow, that is amazing!!! I just finished putting it into a Cube case, but I think I'm going to buy an Apple floppy drive on eBay now, cuz that's just too cool to not try! :-) Thanks!
さんによる
legitt +
さんによる
+ I forgot about that one. It's good.
さんによる
コメントを追加
How about buying a cheap generic mini-pc case? You can also often get those with a built in power supply, which is useful.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
For example, a quick eBay search turned this up, I'm sure you could get much cheaper with more thorough searching, and for Used as opposed to New parts
さんによる
Great idea Rab! I'll take a look.
さんによる
コメントを追加
Duct Tape
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I like the idea, but wouldn't that run the risk of making the computer overheat?
さんによる
コメントを追加
回答を追加する
rdklinc さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 21
過去 30 日: 33
今までの合計 4,829
