My device is not charging
I NEED HELP!!! When I plug my Polaroid into the charger, it will not charge! What should I do?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
It seems that the charging port may have some issues. Try to open your tablet and remove your motherboard. You should either try to reconnect the charging port with the motherboard or you will have to replace it. You can order it online and this charging port is the same for almost all polaroid tablets.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 10
今までの合計 706
