メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
GoogleとSamsungが共同開発した、Nexus製品ラインの10インチタブレット。
optimizing apps at startup
When starting up it begins optimizing apps and never quite finishes. After repeating this several times over a few days, it now begins the same way but in a short time it blinks and then goes dark.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
I found a solution that need no flashing.My s6 edge plus behaved same way.I left like that because I did not want to lose some applications. On the third day it booted normal.
さんによる 共有
コメントを追加
4件の回答
ベストアンサー
This could be a memory glitch . Holding a bad boot in the memory and booting off the same boot cycle. open the tablet and disconnect the battery then reconnect and reassemble and reboot . This video will help you disassemble the tablet the battery removal is not necessary just disconnect the battery and reconnect .Hope this helps
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
最も参考になった回答
If you have Zedge, this is what is causing it.
I had also done other updates and thought it was Android System WebView as it started right after that had updated. Then I read it's Zedge and I've had that program for almost 2 years. I had restarted phone and was again stuck on "Optimizing", but for me each time it has been a good 20 minutes.
I uninstalled Zedge and it started right up, no Optimizing. Thanks for everyone who figured this out!
このアンサーは役に立ちましたか?
スコア 4
8 件のコメント:
OMG thank you soooo much! It worked and I didn't lose my ring tones! I guess when I'm ready to change them I'll just reinstall then uninstall when I'm finished
さんによる 共有
Yes, Zedge is the culprit, just uninstall, reboot and you are good to go.
さんによる 共有
Worked! Thanks
さんによる 共有
Genius once I uninstalled Zedge the optimizing 1 of 1 was gone this really worked thanks a bunch
さんによる 共有
I uninstalled Zedge and the phone still goes into Android starting 1 of 1
さんによる 共有
3件以上のコメントを表示
コメントを追加
I disconnected the battery, then recharged completely. The nexus started back up like it should. However, the screen does not respond to touch. Yikes! I must have messed something up.
Any advice?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I know this is a long time ago,but…
Ensure that the ribbon cables you disconnected to replace the battery are fully and properly reinserted.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
David Lovin さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 14
過去 30 日: 40
今までの合計 17,159
