メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2005年にCompaqから発売されたノートパソコンです。
Why is my keyboard unresponsive?
I turned on my computer and began to type in my password and noticed as i hit the keyboards keys nothing was happening , what can i do ?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Hi Solomon,
If you're having trouble with your keyboard, it could be for a number of reasons. If a few keys aren't working, you may have debris under the keys. If the entire keyboard is not working, maybe it has sustained liquid damage and needs to be replaced.
Here's a link to the Troubleshooting Guide for the computer. It will help you determine what your problem may be and how to fix it.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Try restarting the laptop. It is possible that the keyboard glitched or the display froze.
Have you recently done any repair work or upgrades to the computer? I have done many repairs on laptops and in all honesty, I have had a few instances where I forgot to plug a few connections back in, resulting in said device not working.
Has there been any water damage? Keyboards are the most vulnerable to water damage, and may need replaced.
If you're tech savvy and good with a screwdriver, I recommend opening the computer up and checking the keyboard cable to make sure it's not unplugged or damaged.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Solomon Abioye さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 13
今までの合計 386
