メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Behringer Eurolive B212Dスピーカーシステムのデバイス情報と修理情報。
Power on and off
Behringer Eurolive B212D power on and off.
When I turn the switch on, it stays on for a couple of seconds, and then turns off by itself. I then have to turn it off, and turn it back on. It will stay on for a few seconds & then turn off again, on its own. What could be the cause? Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
marekman101 could be bad capacitors or MOSFET on the power board. You'll have to disassemble it and take a look at the board for obvious failed components like domed or leaking caps. Check these guides to help you. Post some images of what you find with your question so we can see what you see. Use this guide for that.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I have a Behringer 550 w ro live speaker that won't come on when you hit the on and off button. Sometimes I can do it 8 or 10 times and it might come on so I just duct tape the button to stay on and when I want to cut the speaker off I disconnect the power supply cord. Does anyone know if this is just a on and off switch problem?
さんによる
@richardtstokes if this "I just duct tape the button to stay on" works all the time, then yes, the issue will be the power switch.
さんによる
コメントを追加
回答を追加する
marekman101 さん、ありがとうございました!
統計データ:
過去 24時間: 9
過去 7 日: 11
過去 30 日: 38
今までの合計 3,426
