My screen is cracked. How do I replace it?
My screen is cracked and not functional. How do I replace it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Emma, Go to the attached links and click on the videos to see how a screen is removed and replaced. Good luck.
このアンサーは役に立ちましたか?
You can't replace just the screen because the screen and LCD are glued together as a unit. You will have to remove the entire LCD unit and replace the entire thing. Check out the troubleshooting page for links to replacement guides.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 3
過去 30 日: 25
今までの合計 4,657
