Why is the touch screen not responding?
The touch screen is not responding. I tried closing all the running programs and restarting the tablet and the screen is still not responding.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If freeing up resources and re-initiating your tablet didn't solve its touch issues, then you might need to open it up to take a look inside. It may be that the connection between the screen and the tablet's motherboard is a bit loose and simply needs to be re-seated. If these symptoms began after a drop, or after the tablet was exposed to water, you may need to replace the LCD display. You can head on to your tablet's troubleshooting page for more info on this matter.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 340
