メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Error code E2 F2
Whirlpool W10632081A dishwasher error codes
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 6
6 件のコメント
No leak, no corrosion on my unit, put dielectric on contacts anyway everywhere. Nothing helps, still have the e2f2 code. Gonna buy a new dishwasher tomorrow :(
さんによる 共有
The mother board replacement was about $60 and easy to replace
さんによる 共有
E2 and F2 error code on a new whirlpool dishwasher model wdt730pahv0
さんによる 共有
Replaced control board, replaced interface! Still have the same dam problem. F2E2
さんによる 共有
Last time this happened i replayed the display module and Voila! This fixed it. Now it has happen again in less that 5 months. WTF. Going to try the W40
さんによる 共有
1以上のコメントを表示
コメントを追加
4件の回答
ベストアンサー
William, As a first step turn power off to machine for 10 minutes and see if it resets. Whirlpool gold series dishwasher error code e2 f2, means main control board is not getting correct signal from the user interface. Turn off power/breaker, remove screws holding inner door liner, remove liner and check/secure/clean all wire connections from front interface and main control board. If all good and still not working the user interface is probably faulty and has to be changed. Check the attached link,instruction and guide on how to access control and wires, Good luck.
https://www.youtube.com/watch?v=rZMU8T7N...
このアンサーは役に立ちましたか?
スコア 16
13 件のコメント:
Thank you so much for posting the link!
My 4 wire contact to the main board was corroded so I de-energized the breaker, then I cleaned the wire contact by soaking in salt/ vinegar solution for two minutes, then baking soda/ water to neutralize. Lastly when i hooked it all up togeather, i added dielectric grease to prevent further corrosion.
God bless!
さんによる 共有
This worked perfectly for us! Thank you SO much!
さんによる 共有
Turned off breaker for 10 minutes and it did reset. Checked connections and they seemed fine with no visual corrosion or loose connection. I noticed the codes after my 15 amp breaker trips for living room lights? It’s a rent house so I’ll have landlord send someone to check out breakers. Thanks for the post!
さんによる 共有
Great info, also did as McHales and cleaned up the contacts, working again! Thanks a lot
さんによる 共有
Thanks a mill. This helped and saved me a bundle. As always give help, get help. Thanks Guys
さんによる 共有
8件以上のコメントを表示
コメントを追加
Thank God that this worked. I could see that water and I think coffee had gotten in along the top edge from a counter top spill. There was water spots and rust above and below the control panel and circuit board. I could see corrosion on the teeth of the circuit board where the power connectors snapped on. A light sanding with a pink eraser, coated with dielectric grease, reassembled and it worked.
To clean properly you need to get the circuit board all the way out of the plastic housing. Go slow and be careful undoing all the clips and tabs.
To prevent future ingress of water from the counter top I used some foil tape to seal the edge between the door and the top edge of the control panel display.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
After a pump failure covered by warranty we experienced a blown mother board also covered by warranty. Because of both issues we were without a dishwasher for 4 months due to parts on back order. Today 3 weeks after the last repair we received the e2 f2 error code. After reading this thread and dreading calling the warranty company again....I followed the steps described in the thread to clean the connector to the mother board. Boom it worked and momma gets clean dishes. It was maybe a 30 minute fix.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I took apart the dishwasher and everything looked good. leaned my control panel. No luck. Bought a new one and replaced it. Put everything back together. Still E2 F2. So it is probably the motherboard? This happened after a countertop spill.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
William さん、ありがとうございました!
統計データ:
過去 24時間: 12
過去 7 日: 59
過去 30 日: 199
今までの合計 119,494
