メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
GE Profile 冷蔵庫に関する情報と修理手順
How do you get to drain plug
where is drain plug in ice box
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Dale, GE Profile French-Door Refrigerator freezer drain, hopefully the attached vid's. will show how you can access drain plug. You can also do a google search yourself(GE Profile French-Door Refrigerator freezer drain ) lots of info. out there.
https://www.youtube.com/watch?v=E9x0xuFL...
https://www.youtube.com/watch?v=IiPRhr6n...
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
thank you very much. took hair dryer and it worked.
さんによる
コメントを追加
最も参考になった回答
Cause 1
Clogged or Freezing Defrost Drain
If the defrost drain is frozen, the water will overflow the drain trough and drip down to the bottom of the compartment. This water can eventually leak onto the floor. Check the defrost drain to determine if it is clogged or frozen. If the defrost drain is frozen, thaw the ice. In addition, flush the drain with hot water to ensure that it is clear of debris.
Cause 2
Water Inlet Valve
The water inlet valve opens to supply water to the dispenser and icemaker. If the water inlet valve is cracked or has a loose fitting, water will leak from the valve. Inspect the water inlet valve for cracks, and make sure that it is tightly secured to the water supply line.
Water Inlet Valve for your GE Refrigerator
Water Inlet Valve - Part # 1472740 Mfg Part # WR57X10082
RepairClinic Item #1472740
Water valve
$108.71
Cause 3
Water Filter Housing
Inspect the water filter housing for cracks. If you discover any cracks in the water filter housing, replace the housing.
Water Filter Housing for your GE Refrigerator
Water Filter Housing - Part # 1477316 Mfg Part # WR17X12469
RepairClinic Item #1477316
Water filter housing and tubing with bypass cap
$175.40
Controls the flow of water in your refrigerator or refrigerator-freezer.の画像
製品
GE Water Valve - WR57X10082
$179.99
Connects the water filter to the refrigerator, ensuring proper installation and water flow.の画像
製品
GE Water Filter Head - WR17X12469
$189.99
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
how do I get to the water filter housing ?tried taking inside apart but was afraid I wouid break something.
さんによる
コメントを追加
回答を追加する
Dale Cambron さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 32
今までの合計 15,148
