How do I remove top of machine?
How do I take top off to reattach part that goes down to initiate draining and spinning. The lid has to be closed to initiate this feature. I stupidly overloaded and that piece came loose.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Marsha, If it was the lid switch that came loose check the link below easy to follow instruction/video to show Kenmore washer cabinet removal, 2nd vid. shows lid switch replacement.
このアンサーは役に立ちましたか?
@marshas with the top loader you usually remove the whole cabinet. Take a look on here. There may be a different way for your issue but we need to have the exact model number and maybe a few images of the part that came loose. Use this guide to post images so we can see what you see.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 22
今までの合計 11,168
