メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
C720は、AcerのChromeOS搭載低価格Chromebookです。2014年に発売され、C710の後継モデルとなりました。
Why did my computer froze?
I was working on my online quiz and it froze on me my mouse was pointed at the scroll down area.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
amiller364 there are lots of reasons for why this may have happened. Did you get it restarted? Any issues with doing that?
さんによる 共有
コメントを追加
2件の回答
ベストアンサー
amiller, Shut down ( hold power button 10 seconds) and restart, run a malware and virus check as this could be an infection.
I hope this helped you out, if so let me know by pressing the helpful button. Good luck.
https://chromebook.guide/chromebook-viru...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Also look into running a power flush on your device. This can be achieved by following Googles Chromebook reset instructions:
(In your case you would shut it down and use the keyboard short cut in the login screen)
Sign out of your Chromebook.
Press and hold Ctrl + Alt + Shift + R.
Click Restart to restart your Chromebook.
In the box that appears, click Reset and sign in with your Google Account.
Note: The account you sign in with after you reset your Chromebook will be the owner account.
Follow the instructions in the box.
Once you've set up your Chromebook, check if the problem is fixed.
THIS WILL RESET YOUR CHROMEBOOK but being a google device all your pictures, documents and the like should be online in the google drive.
This will fix %95 of software issues.
If it does not look into creating and using a recovery USB drive and finally if that doesn't work chances are it's hardware and being a chromebook it's often simpler to replace it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
amiller364 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 645
