メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ソニー製の40インチ液晶HDテレビシリーズ。
tv has no picture
my KDL-40EX500 Sony Bravia lcd tv was on the floor when the cat jumped on it and knocked it over now I have no picture and looks like no power.What could be the problem
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
Hi, What is the model number of the TV? Also just verifying that there are no power light indications when you turn on the TV? Was the TV powered on (not necessarily turned on) at the time it was knocked over?
さんによる
Tv was not plugged in at time and there are no power lights on when plugged in and turned on.Model no KDL-40EX500 Sony Bravia
さんによる
Anytime am watching. The video went OFF and ON in every 4 seconds. So what could be the problem
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi,
Not being connected to the power at the time suggests that something has either come loose or has been broken due to the fall. Disconnect the power and remove the back cover from the TV and visually inspect for anything obviously broken or loose. If nothing is obvious take some close up pictures of everything in the back. Circuit boards, connectors etc and edit your original question by adding the pictures to it and someone here may be able to spot the problem
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
michael さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 18
今までの合計 438
