メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ALCATEL製のAndroidスマートフォンの修理ガイド。
Why does my phone keep restarting?
My phone keeps restarting, it was on 90% when this started and it just turns onto the alcatel one touch screen then restarts. I have no idea what to do , I think it might have overheated but that was 4 hours ago. Please help me.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 15
15 件のコメント
Apart from doing a hard re-start, a lot of websites recommend uninstalling any recently downloaded apps that could be impacting on the phone. It is a bit tedious but it is the next step to a hard re-start. Mine has scaled down re-starts although I now have a different problem - with my micro sD caught in the "preparing SD card " and "remove SD card " loop!
さんによる
My phone keep s telling me that it needs the first email. It phone # what could I do
さんによる
Mine also keeps restarting, I have done a hard re-set/start and it's still doing this. Please help.
さんによる
Mine keeps restarting. I restarted it and then it will restart on its own. I can't reset it because it shuts off immediately. I removed my sd card but it wasn't damaged. My sim card does not work too but it works on other phone.
さんによる
After trying everything that has been recommended, I finally decided to do a hard reset. However, when I checked my google account to make sure everything was backed up, I found my contacts weren't. Nothing I tried would get them to back-up, so I called Consumer Cellular, my provider. We eventually discovered that my contacts weren't synched, and there was no to get them synched without re-entering them, one by one. That's when I discovered that the Contacts app that came with my phone was not Google Contast, but some knockoff made to look like it. I am guessing that it was Alcatel's version embedded in the OS, because so far, I have not been able to remove it. However, I was able to download the Google app, and import my contacts from the knockoff app. Then synching to my google account happened seamlessly, and I was able to do the hard reset. I haven't had any problems since! So much for Alcatel, yay for google, and special yay for Consumer Cellular.
さんによる
10件以上のコメントを表示
コメントを追加
8件の回答
最も参考になった回答
Install "battery repair" app and "super battery" app your phone may stop crashing it worked for me ✌✌✌
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Why do they ask for a credit card if the app is free?
さんによる
By the way, a new battery did "not" help.
さんによる
Please reply to allanmin@optonline.net. Thank you.
さんによる
コメントを追加
Next time please give more details like the phone model and OS. In the meanwhile, you can try a hard reset - yes - you will perhaps lose all data in the internal memory. If you have a micro SD card in the phone, remove it.
Try pressing Vol UP and Power for > 6 seconds. If you get a menu, then select factory reset.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I have tried it twice and it doesn't work at all is there anything else I can do after that.
さんによる
Mine does not have factory reset button
さんによる
I've just done that but know it still on the reboot screen
さんによる
コメントを追加
What i have found recently is that mine shuts down when opening Facebook. I tries a reset and then a Facebook re instal but today it has done it again. Its also that if you are using too much memory apps etc. Try clearing the cach or junk files. The other thing is that these phones seem to get hot and sometimes wont turn on for a while. Maybe get a cleaner with CPU cool down. Richard
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It seems that facebook and Android have some sort of argument and that's why Facebook keeps dumping my phone. With regards to the memory card it could be the card itself. Try a different one and seem if that helps.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I would let the battery go flat and leave the phone for twenty four hours after it has gone dead. I had an Alcatel that died to I thought it was broken. Two months later it switched back on again......
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
my alcatel onetouch conquest dose the same thing it keep restarting constantly and non stop
さんによる
さんによる
But I tired backing my contacts up and it worked just fine on my idol 4s, and hard resetting did not fix the problem at all, I I did it yesterday after backing up and it had absolutely no effect, and as I said I'm pretty sure for most people it's a hardware problem that can't be fixed through software, and you have to replace the power IC on the motherboard or else
さんによる
Replacing the battery seems like one of the most common fixes as well, but the service center employees told me that the problem isn't in the battery, not sure about that
さんによる
コメントを追加
Alcatel idol 4s 6070K is a complete thrash, keeps getting hot and rebooting, battery used to charge faster but now charge very slow. What is the possible cause of this?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
No the phone is really amazing, what you are experiencing may be because of a cable or power adapter that are incompatible with fast charging or broken, otherwise you need to see a service center they may have to replace your board or battery or even both!
さんによる
コメントを追加
I found the way to fix it everyone,you just have to replace the battery, I did so and mine now works like a charm, you can find batteries on eBay for anywhere around 25 dollars, and just take it to any service center and they'll replace it for Max 5 dollars, if you can't ship from eBay then services such as aramex or FedEx can help you shipping it to you
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My phone 1 minut intervel automatically restarting
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Alex Fisherman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 25
今までの合計 41,261
