Water damage charge not working?
My husbands fitbit charge got wet and will not work now - where can I get it repaired?
Get a quart size ziplock bag , Place your fit bit into ziplock bag cover the fit bit with rice , regular rice that is bought in any grocery store , lock the bag closed for 24 hours . After 24 hours the moisture should be absorbed , see if this helps.
このアンサーは役に立ちましたか?
I have met same problem before. Just put it in the the rice. After 24 hours the smartwatch work again
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 1,966
I went swimming with my Fitbit watch , didn’t. Go underwater. It no longer works.
Kate Wood さんによる
