メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Brother MFC-J6920DW ワイヤレス多機能インクジェットプリンターの修理情報。モデル番号:MFC-J6920DW。2012年9月にAmazonで販売開始。
Shutting down when plugged in.
When I plugged in to the outlet, the screen says ,"All functions will be disabled" then it says" Stand by on/off resume". Then it shuts down.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 28
29 件のコメント
Is it plugged into a outlet controlled by a light switch? If so , make sure the switch is on. I have done this.
さんによる
I have done this also, but the printer wouldn't come alive at all.
さんによる
Thanks a lot. This was the solution. I would have never thought of myself. My printer now seems to work.
さんによる
When I plugged in to the outlet, the screen says ,"All functions will be disabled" then it says" Stand by on/off resume". Then it shuts down.how to solve this problem
さんによる
please reply me
さんによる
24件以上のコメントを表示
コメントを追加
4件の回答
ベストアンサー
Had exactly this problem on a 3 year old MFC-J6920DW today - found a solution elsewhere on the net:
Remove power cord and wait 30 seconds. Then remove paper trays. Reconnect power cord and switch on at the wall. Wait for printer to boot (and complain about lack of trays). Reinstall paper trays.
All up and working now!
このアンサーは役に立ちましたか?
スコア 156
130 件のコメント:
Fixed problem immediately. (problem started with an inadvertent unplugging of the machine)Did not have to hold power button after plugging back in with trays removed, but some had suggested that. If this hadn't worked, i would have tried removing trays and holding the power button till the music stopped.
さんによる
Fixed the problem right away! Thank you so much! Gary
さんによる
Followed instructions about moving paper tray and everything now works. Thanks so much. Janine
さんによる
03/05/2017: Followed instructions about removing paper trays; plugged in; printer rebooted automatically, then requested insertion of paper trays. All is great now. THANKS!!
さんによる
I had this issue too and tried several "fixes" without success. I was afraid my printer was hopelessly dead. And, frankly, I had little faith in this suggestion - but it worked!!! I'm back in business and very grateful that someone presented this solution.
さんによる
125件以上のコメントを表示
コメントを追加
Theses methods are only workarounds. Real source of problem is that the supercapacitor (GC.5.5V0.22F) on the motherboard is out of order.
Change it and the printer will work as before.
Thanks to My Brother Printer EMFC-J4510DW won't turn on for the solution !
このアンサーは役に立ちましたか?
スコア 8
3 件のコメント:
ok mais comment faire pour changer ce super condensateur de la carte mere (demontage) ??
さんによる
hello, see here to replace supercapacitor
https://es.ifixit.com/Gu%C3%ADa/Brother+...
or writte in google: brother problema supercapacitor
さんによる
i tried those steps but still my brother dcp-t710w does not work still shutting down after i plug it in
さんによる
コメントを追加
Yay! Trying to figure it out most of the night thinking my 10yr old printer was gone.
Googled in the & found this tip & bam 5 seconds fixed.
Thanks heaps.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
What can I say that hasn't been said before? Thank you and it works, an absolute dream: you hero!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Fe さん、ありがとうございました!
統計データ:
過去 24時間: 8
過去 7 日: 54
過去 30 日: 282
今までの合計 96,351
