lines on the screen
i have coloured lines on the screen and a beeping noise
この質問は役に立ちましたか?
Hi,
Unfortunately for you the 6 beeps indicate that there is a problem with the video unit in your laptop. This usually means either a replacement motherboard or possibly a professional repair.
A repair by a reputable, professional Dell authorized service centre may be possible but it will probably be cheaper to replace the motherboard.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 16
今までの合計 323
4 件のコメント
Hi,
Do the lines on the screen appear as soon as you start the pc or only when it boots into Windows? Is there a pattern to the beeps e.g. does it go 6 beeps - pause -6 beeps pause etc?
What is the exact model number of your laptop?
jayeff さんによる
The model is 5050-0705 and yes it does 6 beeps and then pauses
shannonmoore200 さんによる
Yes lines appear as soon as i put the laptop on..
shannonmoore200 connect an external monitor and see what it shows.
oldturkey03 さんによる
