Engine will not turn over
After replacing my fuel pump, my vehicle started up. But then the next day nothing. Did not turn over. When i attempt to start it i get a clicking sound.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
Have you checked your battery cables are securely connected and that the battery is not flat?
Usually a clicking sound is the starter solenoid engaging but there is not enough power for the starter motor to turn over.
このアンサーは役に立ちましたか?
You either have a bad starter,battery or alternator. Or you just have a bad ground on your fuel pump ground.
Try jumping the car and or tapping the starter with a hammer
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 21
今までの合計 874
