メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
7インチ画面を搭載した、改良された第2世代のGoogleブランドタブレット。
Reattach locking connector to board
While trying to repair a Nexus 7, the locking connector was removed from the Main Motherboard (sigh, it was taken off by mistake). Nothing else happened to the motherboard and the connector came off as clean. Can the connector be reattached by soldering it back on, or will a new motherboard need to be ordered?
The place where the connector went is pointed to by the tip of the screwdriver.
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
Your picture do not give any idea what is going on. If you want to know the answer and get help, please post detail picture of the system and how it look like. Then you can get the right help.
さんによる
davidshanlay the pictures that are posted with the question look good to me. You can clearly see the solder pads where the connector was once attached to.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
@nexusnex if the connector is still in good condition it can be soldered on. Make sure that the solder pads on the board are all okay.
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
I think they may mean just the plastic piece on the ZIF connector.
さんによる
It's the whole piece that contains the plastic lock and the connector. Even though the connecter was not connected by solder - it can be soldered on?
さんによる
@nexusnex post a couple of good images of the part and where it belongs with your question. That should help out a lot. Use this guide iFixitでの質問に画像を追加する方法 for that.
If the part was not soldered to the board before, there will be no solder pads to solder it to.....
さんによる
Thank you. Post edited with a photo. I suspect it can't be attached, but worth a shot. If it can't - is the only solution to get another MB?
さんによる
Yep, those are solder pads. So, that connector needs to be soldered to the board. If you post a picture of the connector and the little "wires" we can probably tell you if it can be re-soldered. Anyhow for a job like that, you'll need some good skills and tools to solder it
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
John Boucher さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 18
今までの合計 568
