Why is troy bilt spray oil from air fliter
why is troy blit spray oil from air filter
There is a breather pipe into the air filter and because of this, you will always get some oil into the filter. What I have found to be the problem on the ones I worked on was too much oil in the engine. It is only supposed to be filled to the line on the sight glass.
Check the oil level.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 12
今までの合計 366
