メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2010年に発売された、オリジナルのPSP 300xの改訂版です。修理のしやすさはそのままです。
Psp 300x Backlight Fuse
Hi Guys!
I have my old PSP 3001, I drop it on the floor. Still turn On and Off, but with out image...
I replacentment the LCD, but still not working.
So I found out that is a BACKLIGHT FUSE,
Please some one tell me
"WHERE IS THE BACKLIGHT FUSE"?
I am tired to find out and get no result!
Thanks all guys who read and help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
There is only a backlight fuse. There is no screen fuse. There is either a problem with the screen, or one of the components on the motherboard. Probably the IC that is in charge of video.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Try checking component ic4104. That's the backlight driver and is located in the 11,C quadrant of side A on a TA-085 v1 board. The part number is TB62752BFUG. Test each connected capacitor to ground in continuity mode with a basic multimeter for a short. If one or more of the capacitors are shorted remove those and check the pads where the capacitors were. If there's still a short on both pads where the capacitors were then put back the original ones. Odds are if there's a short to ground but doesn't go away when you remove the capacitors then TB62752BFUG needs to be replaced.
PSP 2k Schematics (~95% 3k)
https://gamingdoc.org/technical-document...
TB62752BFUG Datasheet
https://www.mouser.com/datasheet/2/408/T...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Josemar Pereira さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 48
今までの合計 1,221
