Replacement cable for Xbox One Kinect
Is it possible to buy a replacement cable for the xbox one kinect? Just the cable? I can't find one anywhere online.
Thanks to everyone!
If you mean adapter there is only usb to Kinect port which can be used for Kinect in order to connect it with XBOX ONE S which does not have Kinect port. If your Kinect has any problem with it's cable you can remove it and replace it but only on ebay I have found (xbox one kinect cable) that's how I search it because there are power cables for kinect for xbox 360
このアンサーは役に立ちましたか?
Not sure if this can help you, but the cable is a USB 3.0 cable with two additional pins, I assume for additional power. The ‘B’ end of the cable attaching to the sensor accomodates a standard USB 3.0 ‘B’ connector directly, but leaves the two additional pins on either side of it unconnected. The ‘A’ end of the cable is obviously, then, also non-standard, but in this case it is not physically compatible with a standard USB-A port.
read: assumptions
If you need the adapter cable for a newer Xbox or for PC (I believe they are one in the same) search for that specifically, as there is no other solution as far as I am aware.
If you need to repair the proprietary cable attached to the sensor itself, then I would search ebay’s damaged device auctions. (or be adventerous with a custom solution using the info above, if willing :D)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 40
今までの合計 1,604
