メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2016年6月発売。モデル番号はA3003(EU)、A3000(中国と北米)。(以下の情報より https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/)
How to answer call?
I am unable to answer incoming calls on my Oneplus 3. I get a phone icon on my screen but nothing happens when I touch it. I can't use the power button or the home button to answer calls and swiping does nothing.
Is this an Android bug? Is there just some way to answer the Oneplus 3 that I don't know about?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
2 件のコメント
I cant find keys but can find buttons but there is no option to answer calls?
さんによる 共有
I want to answer my call with the home button on my OnePlus 3. But there is no answer call option in the buttons menu.
Please help
さんによる 共有
コメントを追加
4件の回答
最も参考になった回答
I had the same problem on my 3T and have found the answer.
1. Press the Phone Icon
2. Press the 3 vertical dots in top right hand corner
3. Press settings
4. Press Call settings
5. Go down to "Receive incoming calls" and move the slider button to ON!
The manual doesn't seem to mention this feature but that cures the problem.
このアンサーは役に立ちましたか?
スコア 7
4 件のコメント:
It works. Thank you.
さんによる 共有
fantastic this works many thanks
さんによる 共有
Thanks Tony, that works. I wonder who thought it a good idea for a phone not to receive incoming calls by default?
さんによる 共有
Brill, thanks
さんによる 共有
コメントを追加
Hi Ness,
I'm not sure what a long term solution for that is, but you could try these steps for a temporary fix:
Go to SETTINGS then -> KEYS -> then under HOME KEY -> select to ANSWER CALL
Ideally in this scenario you can now press your home key to answer an incoming call.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
You do not need to play with the settings actually. Answering the phone is slightly different on the OnePlus.
You put your finger on the middle "blue" handset circle first and then swipe to the right , towards the small green handset to answer, or to the left towards the small red handset to reject.
I.e. it does not work like most other phones by simply swiping across the screen.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
in ur settings theres a pick up option to answer. im trying this cause i cant answer either.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ness B さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 30
今までの合計 9,957
