My screen is fuzzy
My Sony Xperia fell down recently and now the screen is fuzzy. The screen is fuzzy but when I pull down the notification menu it becomes normal. Is there anything I can do or do I have to change my Led screen
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You will most likely need to change the display assembly.
To clarify the LCD, digitiser all together. Any Sony Xperia where the glass cracks renders the touch screen unusable anyway.
So you will need to replace the whole screen, you can't just replace it separately as they are fused together and is not a diy repair to replace glass only.
Updated:
Guide to replacing screen:
Where to buy the part:
eBay - http://www.ebay.com.au/itm/Black-NEW-LCD...
Eddogo - http://www.eddogo.com/original-lcd-displ...
Screen adhesive from Eddogo: http://www.eddogo.com/front-back-sticky-...
このアンサーは役に立ちましたか?
Please what do you mean by that? Do i need to get a new led screen or just fix the current one
You need to get a new led screen (LCD with touch screen / digitizer). If you plan to replace it yourself make sure to buy the front screen and back cover glass adhesive.
@benjamen50 to improve your answer, give a link to the guide and part ;-)
@mayer Updated post and thanks again. :)
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 3,427
