メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
I messed up. Where (if possible) can I find this?
Also what is it?
My phone got wet, I took it apart and got down to the logic board without a hitch. Was in the process of taking off the EMI shields and I popped this wire off. It has connection and isn't soldered so if I can find on I may be ok.
As you can see, the top part of this wire got pulled out of its housing that would snap onto the PCB. The red arrows are pointing to the locations on the PCB that these ends would snap to.
Edit for response to comment:
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
Look at this on eBay http://www.ebay.com/itm/121486215996
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
You're the man! It's my first time even opening an iPhone so I don't know much other than the basics that I've read about before jumping in. Hopefully I can pull it off.
さんによる
In the meantime, exactly how wet did the phone get? Did you turn it off immediately?
さんによる
No worries bud, that's actually not bad for your first logic board removal. But listen, there are several easy to make mistakes when working on iPhones that will instantly leave you with a pile of Apple branded trash. One of the most important is screw placement. Every screw must go back in the hole it came from! There several different lengths of screws in the phone and if put one that's just a millimeter too long in the wrong it will drill through the logic board and then bye bye iPhone. I'm guessing you didn't know to keep the screws perfectly mapped out when you were taking apart?
さんによる
It got pretty wet... about 5 minutes in the washing machine. Details on that mishap can be seen here:
White screen of death, "normal" start up
Thanks for the compliment! I feel like I could have gotten away without issue if I had one of those nifty heat air guns. I did, however, manage to keep all of the screws mapped out! I did a bunch of reading prior to opening the phone and was lucky enough to pick up on some good tips. (check out edited post with picture of that)
さんによる
HUGE bonus question if anyone can follow up... Does it matter which way that flex cable is put on, on end versus the other?
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Albert Einstein さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 89
