How can I clean out my Lightning connector?
My iPhone 6 seems to have something stuck inside the Lighning connector. As a consequence, I can't get the charging cable in, so can't charge the phone. Is there a recommended way (or tool) for cleaning it out?
Thanks in advance
この質問は役に立ちましたか?
2 件のコメント
This is probably bad practice but I clean lightning dock charger port holes with tweezers or a equivalent tool and make sure to not touch or bend the charging port pins inside the port.
Ben さんによる
I'm embarrassed to say but I also had a loose-fitting charging cable and thought the metal connectors were loose. Turns out that it was filled with lint. A pair of needle nose bent forceps were used to tease out a giant bezoar of lint from the connector cavity and now it works like a charm!
Stephen さんによる
