メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ユニークなスライド式バッテリーと、複数のハードウェア拡張オプションに対応する着脱式I/Oモジュールを備えたLGのフラッグシップスマートフォン。2016年4月発売。
half the screen has dark lines
Half of my screen has dark lines going through the left side of the screen and it will not respond to my touch. The battery is also overheating each time I put it to charge. What do I need to do to fix both of these issues?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
2 件のコメント:
Is the screen cracked? Waterdamage? Repaired before?
さんによる
Hey Cristal, I would defiantly like a little more details, how did it get like this? Did it drop or has the device been exposed to water?
さんによる
コメントを追加
4件の回答
The screen is not cracked and has never been repaired before. About one month ago water did get to it but it did nothing to my phone. My now ex boyfriend had slammed my phone on the ground 2 to 3 times.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Whoever had slammed your phone has caused the problem. Get a new screen.
Update (02/02/2017)
Is it cracked? How long have you been using it? If you have been using it for a long time, try getting a new battery. If it's cracked then you should get a new screen. If it's not cracked then open it and if there isnt a wire connecting to the screen, look at a teardown to see what goes where.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have a similar issue and saw that with a dif. model several people had the same problem as well. The prevailing sentiment is that it is a defective battery and can be fixed by replacing said battery.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I replaced the battery, but the screen still has black lines and won’t repond to touch.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
cristal rosales さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 2,453
