メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年9月9日に発表されたこのデバイスはApple初のウェアラブルデバイスです。iFixitの修理マニュアルは、Apple Watch(ステンレススチール)およびApple Watch Sport(アルミニウム)に対応しています。
Rear Adhesive on Watch?
The back of my Apple Watch fell off. It still functions. The heart rate monitor needs to be plugged back in and there needs to be some kind of adhesive or seal to seal down the rear round ceramic piece back onto the watch.
Are there any parts available for this? thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
5 件のコメント
I have had a similar problem. The rear ceramic piece fell out when removing from the charger. It pressed back into place and all functions still work, but I would love if there is a way to fix it properly.
さんによる
I would contact Apple about this. Even if it's out of warranty it's something they should know about. The main problem is that you've lost the water resistance. So the repair has to be done correctly.
さんによる
I have this problem - Apple want's $199 plus shipping $6.95 minimum for out of warranty. Bought watch new for $250...
さんによる
Scott, Apple is covering this under an extended warranty! Original Apple Watch, if you have a Series 1 or Series 2 that maybe the difference.
You should visit an Apple Store or Apple authorized service center. Make sure you have a copy of the article in hand. I suspect the person you spoke to did not know of the update. You might want to try again if you need to ship it.
さんによる
Yep, Apple replaced mine no problem. They are officially fixing this problem, even if you are out of warranty or AppleCare.
さんによる
コメントを追加
2件の回答
最も参考になった回答
Surprisingly Apple has an extended warranty program for this problem! Bring your watch in to an Apple Store for the free repair.
For reference: Original Apple Watch gets extended service coverage
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Here's what one person encountered: Is the Back of Your Apple Watch Falling Off?
さんによる
コメントを追加
Brought mine to the Apple Store. They are no longer repairing this issue under warranty. I missed the extended warranty repair window by 6 months.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ricardo CD さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 2,029
