メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Microsoft Surface Pro 2はタブレット/ラップトップが融合したもので、2013年に発売されました。Surface Pro 2はMicrosoft Surface Proの後継モデルでWindows 8.1からWindows 10に対応。
LCD ribbon cable dmg
Hi,
Today got new LCD display + touch after I connect everything nothing dosent show on screen but surface sound as working. Also when setup old broken lcd nothing happent. So I think lcd ribbon cable is dmg , here is image of cable https://postimg.org/image/xemi57umf/ i, down right corner look as dmg missing small part of connector. How can I fix? Because new cable cost 50$ , so if can will like to save that money
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
ベストアンサー
Hi,
I solved problem by replacing ribbon cable. You can find on alibaba for arround 5$.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have the same problem. I brought and connected up a brand new LCD screen for my Microsoft Surface Pro 2 but although all the sounds and vibrations are working perfectly on the device I can't seen to get the display to show any visuals. Has any body had and solved this issue and if it is a faulty display ribbon, does anyone know where I can buy a new one from for a reasonable price.
Thank you.
Kay
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Cheers Flegy.
I've ordered a new ribbon from Alibaba but couldn't find the same sort of bargain as you. I paid $18.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Ye when I was order before few years cable was cost 5$ now price is from 10-20$
http://s.aliexpress.com/6zaMZzuu
さんによる 共有
コメントを追加
Same issue. You may find that the screen works but it's the back lights that aren't functioning. You can test this by angling a flashlight to the screen while the unit is on. You should be able to see the graphics but very dark. Another way is to connect the mini display port to an external monitor. This worked for me.
Back to the issue. I replaced two screens and one costly cable but none of that helped. I have the option of connecting to a docking station. My Surface Pro 2 can no longer be used as a tablet.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
So sad to hear you didn’t solved screen problem. I replaced on my surface LCD + ribon and it work fine.
さんによる 共有
コメントを追加
回答を追加する
flegy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 47
今までの合計 2,269
