メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
My phone will not turn on after a screen replacement
My iphone 6 screen was cracked on the top right corner and non visible cracks on the actual screen. My brother tried to attempt to do a screen replacement but could not because it was just too difficult. So instead he pieced the iphone together and at first it wouldnt close in all the way. After several attempts at this, it finally squeezed in. I tried turning it on but it wont budge. I tried the 30 seconds reset but no answer. I ordered an LCD replacement to see if that will successfully turn my iphone on. I need answers asap.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
When you get the LCD replacement follow this guide to the t
iPhone 6のスクリーンの交換
It's possible other things have been damaged. But we'll cross that bridge when we get there. If you have any questions the volunteers here will be more than happy to help you
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
The iPhone 6 replacement screens are usually pretty easy to put back on. With what you explained with the problems getting the screen back on maybe you caused damage to the LCD. Try the new screen and see what happens.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
How is it too difficult...? It's only 5 screws total.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Probably because his friend probably had no idea that the screen assembly has a clip / whatever it's called from the top first then slot it in the phone starting from the top to bottom.
5 screws total?
That is if you have the home button and front camera assembly and LCD metal shield plate pre-installed.
Besides you'd want to keep the original home button which would need to be transferred from the old broken screen to the new one to retain touch ID functionality.
さんによる
コメントを追加
回答を追加する
Gladys Fernandez さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 89
