メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Aspire 7741Zは、17.3インチのHDワイドスクリーンLEDバックライトディスプレイを搭載したAcerのノートブックです。
My screen is pink.
Good afternoon,
I'm hoping someone can help me.
I have an Acer Aspire 7741z-4433. Took it apart to clean the fan one day, put it back together and the screen has been pink ever since. Any white backgrounds, graphics, etc. are now pink. The screen also looks a pixelated and seems to have a flicker or some type of vibration going on.
I searching for an answer for weeks and haven't come up with a thing. Took the laptop apart about 5-6 times to check all connections, wires, etc. Nothing looks broken, loose or out of place that I can see.
Is there something I'm missing? Any ideas on what it could be? I thought it might be the LCD video cable and replaced it, but it's still the same.
Any help would greatly appreciated.
Kathy
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
To determine if this is the GPU or a damaged LED, cable or driver board hook it up to an external monitor and see if it is having problems. Let us know your results.
このアンサーは役に立ちましたか?
スコア 2
7 件のコメント:
Thank you for your quick reply. I really appreciate it.
I have it hooked to an external monitor now. There is no pink on the external.
さんによる
Run your finger across the bottom of the display pressing lightly and see if you get a reaction.
さんによる
Nothing happens.
さんによる
Now try doing it across the bottom of the LCD frame, pressing harder. There a board in there and sometimes this will tell you if it's damaged.
さんによる
Still nothing. No changes.
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Kathy Cyr さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 16
今までの合計 1,867
