メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
Home button not working after battery replacement - Touch ID still is
Hello,
I recently replaced my battery in my iPhone 5S however the home button does no longer work. Touch ID is still fully working however Does anyone know why this is?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
4件の回答
ベストアンサー
تحتاج الى تغير زر الهوم المنزل ولكن لابد ان تأخذ بالاعتبار ان عند تغير زر الهوم ستفقد خاصية البصمة
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
It's means you have partially ripped / damaged the home button ribbon cable assembly.
Unfortunately the only option is to either get it repaired or replace the home button but without touchid functionality as the home button that comes with the phone is linked to the board.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
You could have very well damaged the home button cable during the repair. Even a microtear in the cable can cause the home button to malfunction.
Also keep in mind that home buttons have a rubber gasket around them. This gasket is very similar to other gaskets (ie engine gasket) that sometimes need to be replaced during the repair due to general wear and tear.
If the home button does not click properly, try readjusting it or replacing the gasket. If your home button in fact did get damaged during the repair, replacing it is simple, but you will not have any touch id afterwards because home buttons are married to the motherboard inside your phone. If they are not able to talk to eachother anymore, then you will not have the touchid option available.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
There are several reasons for this problem for example pry damage, a malfunctioning lightning port and so on. You should troubleshot the problem by following this guide: How to Fix iPhone Home Button Not Working after Battery Replacement
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Skinless Gaming さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 1,960
