メインコンテンツにスキップ
2015 Retina MacBookの最新モデルです。モデル番号はModel A1534, EMC 2991です。
Possible to unplug camera and microphone(s)?
Is it possible to unplug the camera and microphone(s) on the 12" Retina Macbook?
I've used past iFixit guides to do this on older Apple devices. For example, in these Macbook Pro teardowns you can see where to disconnect the iSight camera and microphone.
Does anyone know if this is possible on 12" Retina Macbooks?
MacBook Pro 13" Retina Display Early 2015 ディスプレイアセンブリの画像
ガイド
MacBook Pro 13" Retina Display Early 2015 のディスプレイアセンブリの交換
難易度:
中レベル
30 minutes - 1 hour
MacBook Pro 13" Retina Display Early 2015 デュアルマイクロフォンアセンブリの画像
ガイド
MacBook Pro 13" Retina Display Mid 2014 デュアルマイクロフォンアセンブリの交換
難易度:
中レベル
40 minutes - 1 hour
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Thanks for the advice, Dan & Larry. I realize that tape/glue/etc is commonly used to "disable" these, but I'd prefer a hardware solution if one is possible -- and it has been possible with other Apple notebooks.
Checking the teardowns for last year's model, it looks like the microphones are unpluggable (and that this doesn't disable the audio jack itself, since that's a separate step). But I haven't been able to find anything similar for the iSight camera unfortunately.
さんによる
コメントを追加
3件の回答
最も参考になった回答
Your only hope here is tape to cover the iSight camera lens & a cut off head phone plug to kill the internal microphone!
This series uses a highly intergraded architecture to such a point there is no means to disconnect internally the camera or microphone physically.
With that said why are you worried? Unless someone has direct access to your system to RAT it, there is no means to spy on you without you knowing.
Besides you can always turn the system off or put it to sleep mode ;-}
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Are you trying to simply disable them or replace them? If you just want to disable them, use black tape for the camera and perhaps unsolder the microphone if it's not on a connector somewhere. Or just use glue or tape.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I had no problem disconnecting the cables on my 11" MacBook.
Furthermore, I have done the same on two Dell models.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Very different animal here ;-}
This series of MacBook is very different than your older MacBook (retina Vs non-retina).
さんによる
コメントを追加
回答を追加する
wizfish mcfrabblegabben さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 1,524
