メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony Computer Entertainmentが製造する家庭用ゲームコンソール。PS4としても知られています。2013年2月20日に初発表され、2013年11月15日に発売されました。
How to test power supply
Hi my ps4 turns on then instantly off. I'm 99% sure it's a power supply fault from videos I have seen on youtube. However I would just like to check my power supply with a voltmeter before buying a new one. My power supply model is ADP-240AR.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 8
1件のコメント
Are you familiar with the washer fix? Have you attempted it? What makes you think it's the psu?
さんによる
コメントを追加
5件の回答
最も参考になった回答
The PSU provides a permanent +5 VDC on the side connector. This same connector has an input, used to tell the PSU to provide +12 VDC on the 2 big metallic legs soldered on the motherboard.
To make basic tests on the PSU you can:
- remove it from the console
- plug it in the AC with the power cord (from this point, manipulate the PSU only by touching plastic parts!)
- connect a multimeter on the side connector and check that you get +5VDC on some pins (can't remember which ones, just test)
- verify that you have 0 Volt on the 2 holes where the big metallic legs are supposed to be plugged in
- use a wire to shortcut the first and the last pins of the PSU side connector, this should tell the PSU to provide +12VDC
- check with the multimeter that you get those +12VDC on the 2 holes
If yes, your PSU seems to be working.
If +5VDC and/or +12VDC is missing, the PSU is the culprit.
You can find tutorials on the net, just search "PS4 ADP-240 PSU Test" for instance.
このアンサーは役に立ちましたか?
スコア 7
5 件のコメント:
Does it work if you just shortcut the side connector of the power supply so it will always give the +12VDC?
さんによる
I'm looking to do this on a different model. ADP-300CR. Just to clarify, I'm wanting to test for 12 volts on the area where the motherboard prongs insert into the PSU?
さんによる
I am getting 5 v output , but not 12 v when shorting the PSU side connector. Can we identify the faulty component and replace it
さんによる
Wrong information!!!
Need to short first and second hole on the left side and not the first and last.
I tried first and last. It doesn't work.
I followed instructions of this post and thought my PSU was bad. I received new one, it didn't power my PS4. After googling, I found that you need to short the first and second pins. I tested my old PSU, it was giving 12 volts. Wasted money on a new PSU.
Please update this post. And readers please take note.
さんによる
on the side connector, the pins that have to be shorted depends on the model number of the psu because the pinout differs from one to another.
さんによる
コメントを追加
1.Plug in two prong power cord into PSU
2. Flip over power supply
3. Insert positive and negative prongs from multimeter into two holes
on the bottom. Be sure they are fully inserted and not touching any
metal or each other.
4. Set multimeter for DC voltage at ~20v.
7. Use a small piece of metal and make contact with the
first (5VSB) and 3rd(ACDC_STBY) pin
of the connection on the side.
Make sure whatever you are using to jumper the pins makes
contact with the metal connectors in the connector.
This turns on the power supply.
8. If you have done it correctly and the power supply is good,
you should get a reading of around 12 volts as shown.
このアンサーは役に立ちましたか?
スコア 6
コメントを追加
Short first and last pin to test the 12 volts output.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi, i need your help regarding my adp-200er from 12xx serie. i'm trying to check if the psu is my problem on my "no power" ps4
so here is my situation. i put black and red sticks inside the PSU, then i try to jump the 4 pins to watch my readings
when i jump the first and second pins i have no readings
when i jump the first and third pins i have the 12vdc reading
when i jump the first and fourth pins i have no readings
when i jump the second and third pins i have no readings
when i jump the second and fourth i have no readings
when i jump the third and fourth i have the 12vdc reading
do you think the PSU is half working? do i have to replace it?
thanks anyway for any advice
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
If your getting the 12v I would have to say Power Supply is GOOD.
さんによる
コメントを追加
you might check your APU chip, if that comes off, or if any of the suturing points come unsutured, then you need to get a new ps4
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Louis Greenleaf さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 40
過去 30 日: 179
今までの合計 58,788
