How to replace charging port?
My charging port is mashed in.
hello,
i do not know the model that well, but normaly it is soldered to the mainboard.
If it is soldered to the mainboard : you have to unsolder the old one and replace it with an other charging port , solder it properly .
there are many guides to solder ports on ifixit
good luck,
Kind regards,
Kevin
このアンサーは役に立ちましたか?
see explanation in other post you have.
You will have to solder. (most likely)
Kevin
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 21
今までの合計 747
