Wi fi has turned off
How do I manually switch the wi fi back on. The computer is not picking up the signal. All other devices in the house are.
1. Press FN + F8 key...This should turn wifi on and off manually. or....
2. A- Go to control panel and select "Network and Sharing Center"
B- Select "Change Adapter Settings"
C- Right click on your WiFi Adapter and make sure it is Enabled
If none of these work, you may have a driver issue with your Wifi card.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 5
過去 30 日: 31
今までの合計 4,805
