LCD screen is black
my cameras lcd screen is black i cant see anything it still takes photos tho but i cant see them?
Can you view the menu settings in the camera’s LCD screen?
If so then the LCD screen is OK and since you can “take” pictures and download them, this proves to a degree that the motherboard is working OK also.
The problem appears to be with the camera’s CCD image sensor or its’ connection to the motherboard.
I cannot find a replacement CCD sensor online or even a teardown of the camera to see how to open it to gain access to the sensor etc to check if anything was loose.
Given the cost - examples only of the camera, it would be doubtful that if the problem was a faulty sensor and not just a connection problem, that you could source a replacement sensor any cheaper than replacing the camera itself.
このアンサーは役に立ちましたか?
Hi Jayeff!
I can view the menu settings in the camera's LCD screen, yes.
When I take photos and download them/hook the camera in to view on the computer, it's just a black rectangle :(
過去 24時間: 3
過去 7 日: 10
過去 30 日: 43
今までの合計 1,582
I am having this problem as well. Did you ever find an answer? Stylus 850 SW camera, screen is black, lens is open, I take a photo and plug camera in to computer and there’s a file there but its just a black rectangle
mormongirl782 さんによる
