メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ZTE Grand X Maxは、2014年10月に発売されたZTE製の6インチスマートフォンです。
I cant make calls
It won't let me make phone calls it hangs up tight away
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 10
14 件のコメント
We need more information. Have you tried turn it off and again (not "sleep/suspend mode," but really powering down)? Have you changed anything recently? Does this happen with all local numbers? Finally, have you tried a factory reset to default state and tried again?
さんによる
I have this problem as well, and I have done everything including a factory reset and still I have this issue. Perhaps a software flaw or something?
さんによる
Same problem makes no sound when dialing and then lists at bottom can not complete because of unspecified error. Many incomming calls go direct to voice mail when the signal is very good. Sometimes can not get to retrieve voicemail. It seams to have no pattern as to when it will not work. I have not been able to call any number for the past day (error caon not complete). 05/17/2017 by sehappraiser@gmail.com
さんによる
I wonder whats wrong ive done nothing else could make calls eariler
さんによる
I couldn't call out, I had tried everything. After 2 30 minute phone calls to Tracfone and doing everything they suggested, still would not call out. When I saw the comment above about putting the phone back to factory setting I tried that and now my phone calls out. I was ready to buy a new phone.
さんによる
9件以上のコメントを表示
コメントを追加
3件の回答
最も参考になった回答
Had the same problem. Try turning off assisted dialing in call settings.
Hope this helped.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Changed setting "Voice over LTE preferred " to off.
Fixed my ZTE Z799VL
To get to call settings (in android 6.0.1) select phone, dialer, and click on the 3 vertical dots on the left side of the text field of numbers.
さんによる
I don't understand
さんによる
Same ph though
さんによる
I turned off everything I could find and now it works.
さんによる
コメントを追加
I put mine back to factory settings and haven't had a problem since. I wrote down my contacts first.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I'm not able to receive calls or call out from my zte phone
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
No able to make calls or receive calls from my zte
さんによる
コメントを追加
回答を追加する
Jessica Jamaica さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 21
今までの合計 17,777
