メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
1998年に発売された、カラー画面、わずかに向上した処理能力、より小型のフォームファクタを備えた任天堂ゲームボーイのアップデート版です。このデバイスの修理は難しくありません。
My Game boy game won't load
I'm having trouble with the Gameboy game not loading on my Gameboy Color. it's "Looney tunes "twouble!" ".
画像
this game has gave me trouble in the past but now it won't boot at all whatsoever. now all I get is the Game Boy Color logo and just "®".
画像
I have tested every of your game on your own and it always results with always booting or requiring a bit of coaching to get it booting
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
18 件のコメント
It may be that 1 of the pins on that connects to the cartridge is bent or something, look inside with a flashlight and see if anything looks amiss
さんによる
I opened it up and it looks completely fine. Also it's only one game that doesn't work out of about 10 that I have
さんによる
I open the game but not the game because I can't open the game cuz I don't have the right stuff
さんによる
I meant Gameboy
さんによる
It may just be that that game has broken... But do the same thing, look at the pis on the game and see if anything is amiss (you don't have to open it) and if everything looks fine the the only way to find out is to open the game up
さんによる
13件以上のコメントを表示
コメントを追加
3件の回答
ベストアンサー
The suggestions by everyone is about as good as you'll get. You'll want to check the pins and give the contacts on the game a good cleaning with rubbing alcohol. If that doesn't fix the situation then one of the chips on the game PCB has probably died. The only way to check a chip (that I'm aware of) is removing it from the PCB and putting it into a tester. Other than that, you would want to inspect the traces on the PCB of the game. run a multimeter from contacts to points on the chip and such. It's a bit of work if you really want find the problem that bad.
このアンサーは役に立ちましたか?
スコア 5
6 件のコメント:
I agree with Andrew here
さんによる
Can you give a better description on how to use the multimeter
さんによる
To check traces, you can set your multimeter to continuity mode and touch contacts to either end. A beep or '0' on the screen will tell you there is no disruption on that trace. Checking chips is a rigorous process and extremely difficult without the correct tools.
One of the only other options you could try is reflowing the solder on the PCB using either a hairdryer (for a long time on high) or a heat gun (for short bursts) to heat up the solder and see about reconnecting any problematic spots.
Probably, in this case, a chip has failed, which would require programming to completely repair and at this point its best just to find a new game.
さんによる
What if you CAN'T find a new game? How would you go about reprogramming it?
さんによる
Hi Joe, I don't know how possible it would be to reprogram a GBC game chip. I know of some YouTubers that do it with NES games but as for "newer" games, I don't think it's possible. If you're still interested, look around YouTube or Google searches to see if you can reprogram a cart and go from there. Best of luck to you on that.
さんによる
1以上のコメントを表示
コメントを追加
Had the same issue of it loading game boy and nintendo but not going past the screen…all i did was blow air into the game and into the back of the game boy and BOOM it turned on YASSSSSSSS!!!!!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I don't understand why people are opening up their cartridges and cleaning up the traces, I'm sure that solves the issue, but just blow into the %#*@ cartridge's 😳. It's just like the NES, blow into the game cartridge, try again. Problem solved....
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
@thecalamity
If you blow into it, introduces moisture which will rust eventually and screw up the cart, isopropyl alcohol completely evaporates. That's why half the old SNES carts don't work, blowing in em
さんによる
@sarahvail
We were having the same problem with it being stuck on the logo screen. We have always blown in the games which made them work, but I was hesitant to do it this time. We did it anyway because the alcohol didn't work. Sure enough everything's working fine again! It's okay to blow in them.
さんによる
@debbiemsj, if you open the cartridge and wipe the pins with alcohol, it will clean the dust and debris from the pins. As another measure, you can put a dab of deoxIT on the pins and rub it on the pins. It also a good idea to wipe the circuit board and components with alcohol as well. Blowing on the pins can introduce moisture to the pins and potentially development of corrosion. I believe if you cleaned the pins with alcohol and that didn't resolve your issue, but blowing on the after worked, you didn't clean them well enough.
さんによる
コメントを追加
回答を追加する
Jake Donovan さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 22
過去 30 日: 124
今までの合計 72,939
