メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony Xperia Z5は、2015年10月に発売されたAndroidスマートフォンです。5.2インチの1080 x 1920ピクセルディスプレイを搭載し、Qualcomm Snapdragon 810プロセッサ、3GB RAM、23メガピクセルのリアカメラを備えています。
z5 Screen stays blank
The led notification light is red, blinks 3 times and then repeats, ONLY when the charging cable is in!
Anyone know how to help? Z5 dual
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
2 件のコメント
Hold the power and volume down button for 15 seconds and see if that helps. That forces a hard shutdown / reset of the device.
さんによる
doing the above just resets the LED notification light to the beginning of it's pattern
さんによる
コメントを追加
3件の回答
最も参考になった回答
guys my z5 had display but no backlight, I have bypassed the "V" and "A" both fuses still theres no backlight can anyone help?
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
I could sell you a screen, cheap lol.
さんによる
jbrown05666, I've just bought a brand new screen and its still the same the problem is the motherboard not the screen
さんによる
My Z5 brightness works only 1/3 at beginning of slider and after that does not go any brighter, testet with 3 different lcd's =(
さんによる
コメントを追加
In my case, before it start to happens, the colume buttons seems not working very well. Then it worsen where I cant turn off my screen when pressing the power button, but it still detects the fingerprint. Then I press the power button withvintentention to restart but it straight away goes soft reset as if I'm pressing power + vol button. I cant turn onthe phone anymore. The screen will turn on when I plug itbto charger,and it will display battery charging icon. But if I try to turn it on it will vibrate 3 times and it will strqight away turn-off just like soft reset.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
But sooner I find a way to turn it on but only in the safe mode..where the apps acess is limited. Connect your phone to pc. The screen will not turn on bit the notification led will lights up in this manner, red>green>off>red > continuous green. If it happens like that, take it off, plug again. Bit this rime, as soon as the first green lights up,, take out the usb immadiately. Your phone will boot up.
さんによる
コメントを追加
we found a solution to this! check both the "v" fuse and "l" fuse. if you have picture but no backlight than you have blown the "v" fuse, if you have no picture but have a backlight check the "l" fuse for continuity as you may have blown that fuse
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
where they are?
さんによる
コメントを追加
回答を追加する
[deleted] さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 8,279
